I am having problems with my pipe lines in the plan view, the lines are being cut off at the structures. And in cases where the segment is shorter, disappearing all together. It's only happening on some networks and it did not draw out like this originally. I tried regen and it doesn't fix the problem. The pipes also are still connected. Anyone else have this problem or know how to fix it?
Try changing your drawing scale and see what happens.
Bill
Also, look at the information I have included below. It is quite easy, use the "My Settings" above right.
Go to the structure properties and select the structure style. On the plan tab there is a toggle box at the bottom for part masking. Uncheck this box and that should fix your problem.
