Distinguished Contributor
cloquet
Message 1 of 4 (250 Views)
Pipe Network Problem
250 Views, 3 Replies
01-09-2012 11:12 AM
I am having problems with my pipe lines in the plan view, the lines are being cut off at the structures. And in cases where the segment is shorter, disappearing all together. It's only happening on some networks and it did not draw out like this originally. I tried regen and it doesn't fix the problem. The pipes also are still connected. Anyone else have this problem or know how to fix it?
wfberry
Message 2 of 4 (237 Views)
Re: Pipe Network Problem
01-09-2012 12:26 PM in reply to: cloquet
Try changing your drawing scale and see what happens.
Bill
Also, look at the information I have included below.  It is quite easy, use the "My Settings" above right.
Active Member
rhouze
Message 3 of 4 (206 Views)
01-12-2012 07:36 AM in reply to: cloquet
Go to the structure properties and select the structure style.  On the plan tab there is a toggle box at the bottom for part masking.  Uncheck this box and that should fix your problem.
Win 7 x 64 8GB RAM
NVIDIA Quadro FX 880M
Civil 3D 2011 SP2
cloquet
Message 4 of 4 (203 Views)
01-12-2012 07:40 AM in reply to: cloquet
Thanks, that worked.
