Civil 3D Forum
Pipe network not showing up
13 REPLIES 13
Message 1 of 14
dan
5827 Views, 13 Replies
I have lost the ability to create a pipe network in a single drawing. Sorta. I can create a pipe network, and label it, and see it in my toolspace, but it won't display it for any style in any format. I can bring in a data reference and label those, but can not see pipe or structure outlines or anything to that end. I have tried to recover, audit, purge. I am at the end, currently creating the pipe network, data referencing it in, and then just drawing lines between the labels.
Anybody have any ideas?
13 REPLIES 13
Message 2 of 14
Ed.McGriskin
in reply to: dan
Silly question but need to ask. All layers turned on and thawed?
Ed McGriskin, P.Eng.
Project Engineer @ HUSSON
Remember to accept the solution so others can find the solution also.
Message 3 of 14
in reply to: Ed.McGriskin
Whoops, forgot about my co-worker logged in. But yep. Everything turned on, nothing frozen. I literally saved a new test file, deleted everything, purged, and audited, and the problem still exists.
Message 4 of 14
ToddRogers-WPM
If you look at your pipe properties, you are using the style Standard.  No good.  You need to use a template file.
Todd Rogers
Message 5 of 14
ToddRogers-WPM
Also, you have no parts loaded in your parts list.  You can't see something that is not there.  You have to create a part list or use a template file.
Todd Rogers
Message 6 of 14
I don't think that is the issue Todd as I have opened up the drawing as well and imported all our company settings. Still unable to draw or display pipes.Still tinkering to see if I can find out why this might be happening.
Message 7 of 14
There are no parts in the catalog.  You can't draw parts if they are not there.
Todd Rogers
Message 8 of 14
Sorry about that Todd. I was talking to someone else at the same time I was typing my reply. Fixed my post.
If the Pipe Catalog that the parts list references does not exist on your machine the list will come up blank I think. I know when I imported our settings, parts list and reference our pipe catalog the issue still exists. Makes me think there is a drawing setting somewhere that is causing the display issue.
Message 9 of 14
I copied over a few different styles and a part list from one that works and still nothing for me either. i can then swap parts to the new parts list, and the same thing occurs.
Message 10 of 14
Ed.McGriskin
I think I got it.
In the Display Manager Settings, both the structure and pipes are set up to not display.
Type in DISPLAYMANAGER on Command Line and Browse to Representations by Object. Find pipes and structures and make sure General Display settings have Model and Plan checked.
Message 11 of 14
Good job Ed.  Kudos for you!!
Todd Rogers
Message 12 of 14
Yep, thank you so much. Just saved me so much time
Message 13 of 14
Ed.McGriskin
No problem.
And now I know how to make people get angry with there autocad drawings.
Message 14 of 14
Jeff_M
If you find a response which answers your question, please be sure to accept the actual post which helped you as the solution. This will help future searchers quickly find answers to their own questions. Thanks!
Rail Community
