Civil 3D Forum
Pipe Network Layers - Setting Defaults?
4 REPLIES 4
2001 Views, 4 Replies
I can't find the setting for setting the default pipe network layers - dialog that opens when I create a network.
I have different utilities, obviously want them on the right layers.
E_WM --> exst. WM layers plan/profile
E_SAN--> exst. sanitary layers plan/profile.
etc.
I have a template drawing I am getting my styles from. where in the template are thse things set?
thanks.
4 REPLIES 4
I am about to set them all again - happens because I may not have something exactly right that I want to recreate the network from the beginning, or the editing later on of the network is more tedious than it is to start over.
I havethe correct layers assigned in the pipe styles. I can't find it in the network style settings, in the general layer settings, and I can't imagine where it could be.
Autodesk - this is very typical - the hunting for where certain settings are. You might want to make Help actually helpful by including a map to the setting locations for all of the Civil 3D stuff. if I use Help about this, all is says is that this is where I set the ayers. well, duh! I kind of knew that. but like everything, there are several places where layers are set, and I am never sure which controls which, and how to make it stick so I don't go trhough this all the time, and what are stye overides all about anyways?
found this in Help: The default object layers are defined from the root drawing settings on the Object Layers tab.
but there is just one setting for a pipe network layer, while in the dialog there are four places to set the stuff: plan pipe, plan structure, profile pipe, profile structure, and XS.
so, I am getting it, I think. I use a "Master" layer to put ALL of my peipe networks on, regardless of whether they are exsting or proposed, then control their displayed and plotted layers states in the parts listing? I mean, without having to edit the stinking layer list all the time?
thanks.
sjg
The way I have it set up in my template is I created dummy networks for both storm and sanitary where you set the layers once. So when you create a new drawing with your template, just edit the existing dummy networks, revise name and description, but layers should be set for you.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
mathewkol
That way works well, but it has a limitation when using data references. You dref pipes into another drawing, thise pipes all go on that master layer.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Rail Community
