Civil 3D Forum
Pipe Network issues MH and pipe inv's not aligning
2 REPLIES 2
HPGarcia70
309 Views, 2 Replies
I created a gravity pipe network with the structures set to null. Then I was told to add a 48" dia manhole at 2 bends. For some reason the sump of the man and inv of the pipes are net matching. I go into the structure propeties and manually set the rim to sump heighth to match the inv of the pipe. But for some reason the inputed heigtht doesn't stick. I made sure the manholes and pipes are connect but it still looses the inputed height. Any suggestions?
This is the second C3D project I worked on.
I'm using C3D 2014 SP 2.
Thanks for any advices
-HP Garcia
C3D 2014
Ver:108.0.4, SP2
i7 3.40 GHz
32 G Ram
NVidia Quadro 200
2 REPLIES 2
Jay_B
in reply to: HPGarcia70
Without seeing a picture of the issue, if your sump is 2 feet below the lowest invert, then apply a structure rule to structure which sets the sump depth to zero.
http://docs.autodesk.com/CIV3D/2014/ENU/filesCUG/GUID-200A9EA6-EECF-48BB-824F-9E901649C4DB.htm
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
HPGarcia70
in reply to: Jay_B
Here is a screen shot of the area I am talking about. This is a stormdrain network. The outlet inv needs to be 0.1' below the inlet invert.
C3D 2014
Ver:108.0.4, SP2
i7 3.40 GHz
32 G Ram
NVidia Quadro 200
Rail Community
