I have a profile view w/ several profiles and a pipe network referenced in this drawing. When i adjust the profile properties to only show 5+00 to 10+00 my pipe network goes wild. Any thoughts to what I need to do to fix this?
If no one else replies with a better answer, I would suggest you place a wipeout ot hatch over the funky areas for plotting and then contact subscription support or your reseller so the creators can confirm there is a bug or log a new one.
John
John Mayo
You probably are right Bill. I assumed it was one pipe going past the profile that was freaking out on him.
John
John Mayo
Have you tried REGENALL?
I've seen this happen when I changed the elevations of a profile view. Regenerating usually fixes it.
Just now revisiting this project, it has been on hold for awhile. Thanks for the suggestions. I did finally get it to clear up. I turned off the profile setting "Clean up pipe to pipe connections" and it went back to normal.
