greetings.....I am creating a pipe network from object, and at the command line is asks if the flow direction is correct, but the arrow is not showing up. Any ideas on how I get that little guy back? thanks for any help.
Solved by Jay_B. Go to Solution.
Does it work after entering Plan >World @ the command line?
If using a UCS other than World the arrows can get shifted off of the objects selected for the Pipe Network.
