Civil 3D Forum
Pipe network - Box culvert
8 REPLIES 8
Message 1 of 9
DaveM
2458 Views, 8 Replies
I am trying to draft a box culvert with a winged headwall using a pipe network. I am having trouble getting the right size of headwall/ wings. My box culvert needs to be 5' tall, by 9' wide. I found the box culvert pipe, but having hell trying to size a wingwall. I added all part sizes in the Concrete Rectangular Box Culvert Headwall Family. How should I go about picking a part size? The attached image shows my problem. The names appear to have three dimensions, I am not really sure what the three dimensions are tied to. Thanks for any help!!!
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
ATI FirePro V5700(FireGL)
Win 7 Home Professional
Please use Kudos Where Deserved
8 REPLIES 8
Message 2 of 9
DaveM
in reply to: DaveM
Ever since they changed the format of this website I have had a hell of a time attaching images https://www.dropbox.com/s/1pqftua5k2btm8g/Box%20culvert.png
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
Message 3 of 9
rkmcswain
in reply to: DaveM
Specific to that issue, what browser are you using?
Do you get the dialog below?
If no dialog, do you have popups blocked?
Are you running any 3rd party pop up blocker or Ad Block?
Javascript enabled?
R.K. McSwain     | CADpanacea | on twitter
Message 4 of 9
Cadguru42
in reply to: DaveM
I just did a box culvert project. I never used a C3D headwall in the pipe network. I just manually drew the wing walls and had a generic, no display structure at the end used for labeling purposes. I found that if you have a bend in the box culvert, C3D can't even handle that, so I just drew the outside walls and inside walls manually. I know that doesn't help you much, but know that C3D isn't made for doing box culverts really.
C3D 2022-2024
Windows 10 Pro
32GB RAM
Message 5 of 9
DaveM
in reply to: Cadguru42
As much as I hate it, I think that may be the way to go!
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
Message 6 of 9
Discussion_Admin
in reply to: DaveM
As was asked earlier in the thread can you tell us what browser are you using? And would It be possible to send the file to me moderator@autodesk.com.
We what to make sure all of our users are able to use the community as intended or try our best to resolve issue.
Discussion_Admin
Message 7 of 9
DaveM
in reply to: Discussion_Admin
Sorry I took so long to get back, I am currently using IE9, but I have tried chrome & Foxfire as well. Sometimes when I long on I have the controls & Sometimes I do not. I had never thought of a pop up blocker, I will see what my IT guy thinks. I noticced the issue right after the change of the website. https://www.dropbox.com/s/spidaae1scn67on/Screen%20Shot.png If you look at the above screenshot. a lot of tools fail to load, with all three web services. I also can not subscripe to a post. when I select the options dialog box no dropdown appears. One last note randomly, it appears it loads like it should and I get the tools to load an image, but I can not consistantly repeat. Thanks, Dave
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
Message 8 of 9
kcobabe
in reply to: DaveM
The fix for both of your problems.
The Bend:
In old C3D you use to be able to leave linework cleanup on for any structure and it would draw your bend.  Not in order to do this you need to use the "null" structure.  This is bad when it comes to labeling your probile as you have to use a lot of profile view labels instead of structure labels.  Still wishing Autodesk would make a label to label pipes vertically where you want without having to use a data band.
The wing wall:
Having had this problem in the past.  You are left with only 3 choices.
1.  You draw it manually in both plan and profile, make blocks of them, and then make a structure using those blocks.
2.  You create a 3D model of it and to get it in your profile you just use the draw drawing objects in profile function
3.  The most difficult, create a modified version of your wingwall part in partbuilder.
All three options will get you to what you want.  Some just require more work than others.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Message 9 of 9
DaveM
in reply to: kcobabe
You really used a creative way to solve this issue. I would have never made it to any of these work arounds. Thanks!
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
Rail Community
