Joe and I talked about this today and I contacted Scott Kent at Autodesk to
ask him how pipe lengths were calculated and I think we figured out why it
might be squirrely:
From Scott:
"For 2D center to center, it's just a simple distance between 2 coordinates
calc. For 2D inside edge to inside edge, it's the distance from outer wall
to outer wall, plus wall thickness of structure 1 plus wall thickness 2,
plus a calc for projection into the structures."
The last part about projection into the structures, etc. seems like it might
give you a slightly different measurement every time depending on how you
hit the structure. A few degrees either way, or a different slope or
whatever might just be enough to throw it off.
I don't know the best solution, but at least we aren't imagining it.
Dana Breig Probert, E.I.T.
http://www.civil3d.com
Civil 3D 2007 SP3 alongside Civil 3D 2008
AMD Athlon 64 X2 Dual Core 2.01 GHz
2GB RAM, 256 MB ATI FireGL V5200
AUGI CAD Matinee in Philly May 17
http://www.cadmatinee.com/philadelphia/default.asp for more complete agenda
and registration.
