I want to create a pipe label that is similar to a dimension style going from end of pipe to end of pipe. I tried making a line component and an expression theat uses the length of pipe but cannot get the start and end points correct. And ideas?
Solved by Joe-Bouza. Go to Solution.
Solved by Civil3DReminders_com. Go to Solution.
Like
this? http://blog.civil3dreminders.com/2009/05/pipe-label-dimension-look.html
Your Name
Your Name
Mark Green
Working on Civil 3D in Canada
That is what I am looking for. two more questions
why does the expression get half the length?
how do I get it anchored to the pipe end?
Your Name
Your Name
I got it. I used the negative or half the pipe length in the x offset.
This is for an unconventional use not a pipe. I was lookint for a way to project cross street names to the profile and be dynamic to alignment and profile changes. I started with a single cogo point projection but prefer to show the street witdth with the name. So I make a dummy pipe network, name thepipes the street names and I have it. I like it. thanks
Your Name
Your Name
Are you looking for this attached file? You might have to log into the forums to see it.
