After creating a few pipe networks, I've found that the only pipe object layers that I can't change (easily) are the pipe labels. I've changed the layers in their respective styles but when I grip a pipe label it is on the default object label. I know that I can edit drawing settings> object layers> pipe-labeling> and change the layer here but I want sewer and storm on different layers. Is there a setting somewhere else that changes this? The pipe object layer can be changed in the pipe network properties but I haven't found where I can change the label layers except for selecting all of the labels (like sewer) and manually changing the them to a (sewer) layer. Any suggestions?
Solved by mathewkol. Go to Solution.
This is what I do. Say I ultimately want these layers for STM and SAN
P-STM-TXT
P-SAN-TXT
I would set the Object layer for pipe labels to "TXT".
I would set up A PREFIX OF "*-"
I would name my storm network P-STM and my san network P-SAN.
Makes sense? You may or may not be able to use this depending on your naming conventions.
