Is there a way to LOCK pipe invert elevations in pipe networks?? We get our inverts set, then if we have to move a junction structure, even a foot horizontally, the pipes shoot to zero elevation and we have to go back and redo them all. Is there a step that I'm missing??? Thank you!!
Jennifer
2015 C3D
I suspect you may be moving the structures in the profile, when you should move them in plan only. You should notice that the pipes are tagging along with the structure.
Bill
No, we are moving them in plan only. I'm not even sure how you'd move them in the profile.
Jennifer
I think you are moving beyond the limits of your surface.
Try toggling the surface to none on structure properties before you move.
Your Name
I'm having the same issue. Is there a system variable or a setting somewhere in toolspace that I'm missing?
There is no toggle for this so save your time looking.
As others said there is no history with a bug and insure you are only selecting the structure, no pipes, no alignments and make sure you are on the surface.
Posting a file is the best way to get help.
John Mayo
