I wanted to adjust the style so the line starts at the invert so I thought no problem I'll write an expression. I wrote
-1*({Pipe Inner Diameter or Width}/2) int the hopes I could use it in the y offset parameter but the expression doesn't show up in the pop down. Infact I have another expression for flow, and if I add several more expressions to my list when I go to the pop down only Flow shows. Is this a 2013 thing?
They are all formatted as Double values, Joe? And they are all expressions created for Pipe Plan Profile labels?
In 2013 I have 5 expressions and all are available to me. This one works works in a 20 scale drawing with Vert. scale of 5
-1*(({Pipe Inner Diameter or Width}/2.0)/{Drawing Scale Conversion})*4
