Civil 3D Forum
pipe crossing display
2 REPLIES 2
nostupidquestions
265 Views, 2 Replies
i've got proposed stormwater pipes crossing existing utility pipes. my proposed stormwater pipes run parallel to but offset from my road centerline alignment. i want to show the existing utility pipe as an oval where it crosses my stormwater pipe. i can get the utility to show up in the profile at the centerline alignment of my road but not at the actual point where the pipes cross. is there a way to show this? thanks.
Intel(R) Xeon(R) W-2245 CPU @ 3.90GHz 3.91 GHz
64 GB RAM
C3D 2023.2
2 REPLIES 2
It will only show where it crosses the alignment so if you need to create an alignment from network paths then use pipe style override, profile crossing pipe to display.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
that's what i figured. thanks.
64 GB RAM
C3D 2023.2
Rail Community
