i've got proposed stormwater pipes crossing existing utility pipes. my proposed stormwater pipes run parallel to but offset from my road centerline alignment. i want to show the existing utility pipe as an oval where it crosses my stormwater pipe. i can get the utility to show up in the profile at the centerline alignment of my road but not at the actual point where the pipes cross. is there a way to show this? thanks.
It will only show where it crosses the alignment so if you need to create an alignment from network paths then use pipe style override, profile crossing pipe to display.
that's what i figured. thanks.
