So I have a proposed storm sewer pipe network and 90% of pipes snap to the structures fine, with a start/lengthen snap on one end and an end/lengthen on the other, and a location/pipe diameter one in the middle. When I go to draw one of the pipes though, I draw structure to structure and it doesn't sit properly. I click on it to make sure it snapped to the structure but there is no start, end, or lengthen snaps on either end of the pipe. Only a Location/Pipe Diameter one in the middle. Therefore, I cannot manipulate it's length or where it connects, I can only move it around from the center.
Solved by ruipfbarreiros. Go to Solution.
Mark Green
Working on Civil 3D in Canada
select the pipe and check its properties...check the elevations of start and end point
that happened to me when I had a start elevation of 0.0 and end elevation of 40.0, making the slope of the pipe too high..
Mark Green
