Can't seem to be able to Export to ACAD 2007 without the following appearing
Recover has found no errors, all XREFS have been bound and I've even exploded AEC objects
Any other suggestions?
neilyj (No connection with Autodesk other than using the products in the real world)
oops. Forgot the link http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Export-to-DXF/m-p/3770180/highlight/true#M194982
Allen Jessup
CAD Manager - Designer
This is when exporting to dwg rather rthan dxf....
I understand. But, without knowing, I'd think that the process is the same up to the point that AutoCAD writes the file.
Allen Jessup
Allen Jessup
Interesting. When I do EXPORTTOAUTOCAD2007 I don't get an error. But I don't get any file either!
Allen Jessup
Civil 3D 2012 SP 2.1
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
Allen Jessup
Yes - I didn't get a file but I assumed the error message stopped the conversion hence no file...!!!!!
When I WBlock the entire drawing to 2007 with MapData. It works without a problem.
Allen
Allen Jessup
@neilyj666 wrote:Yes - I didn't get a file but I assumed the error message stopped the conversion hence no file...!!!!!
That I would expect. But even without getting the error I still didn't get a file. I'm searching my hardrives and network in case it was created in another path. No results so far.
Allen
Allen Jessup
I've encountered this behavior as well. I don't have an explanation or solution but I thought you'd like to know that others have seen this too.
