You know, there are probably as many opinions on this subject as there are
users! I for one try to educate my users as to the best approach when
working with multiple drawings and multiple engineers. If you're placing
all your eggs in one basket, you're simply putting yourself at risk for
creating corruption in multiple drawings (tabs) rather than just one or two.
Granted, I've not seen many drawings becoming hosed in a while since the
software's continually getting better and better, but, the fact of the
matter is that, as I believe Mr. Postlewait stated, if your drawing goes
belly-up, you're only gonna corrupt one sheet, not an entire project.
If you're holding back because you think it's more difficult managing
sheets, then you really haven't taken advantage of the sheet set
functionality in basic AutoCAD. And dare I say anything about Civil 3D
2008? Well, let's just say that you should really rethink the method you're
using for putting your drawings/sheets together, one drawing/one tab is our
standard and it works very well, particularly using sheet sets and sharing
amongst multiple users.
But if you insist on keeping all your drawings in one file then you might
also consider going into the options dialog and setting your layout regen
option to only cache the model tab and last layout rather than all layouts.
That'll force a regen when you switch tabs, which will obviously be slower,
but it'll free up the memory that can be consumed fairly quickly with the
number of tabs you're using.
Good luck with whatever route you dedice to puruse.
Kelly W. Boyd
CAD/CAE Support Engineer
Pierce County Public Works
Tacoma, WA
wrote in message news:5423321@discussion.autodesk.com...
Another thing is it the Viewports causing the performance issues?, or just
the sheer volume of Layouts?
The Xref concept may work, I certainly wouldn't go down to single drawings,
workflow would be reduced having to jump from sheet to sheet, but I guess
with the regen times we are seeing now with viewports this may be about the
same. Just managing that many sheets is what holds me back from this
concept, our Plans range from 50 to 70 depending on the project each year.
Some thoughts...
1. You go to a single drawing for each sheet, xrefing your base drawing.
This would obviously help performance but at the cost of managing more
files(.dwgs)
2. You break the project up in parts, having 10 to 15 layouts per drawings,
xrefing in your base drawing. Would we see a significant performance
increase using this method, or is this still to many layouts/viewports? I
may try this after this years project, using our current one, we are too far
along to change things up with deadlines around the corner.
