Civil 3D Forum
Pedit vs Join
8 REPLIES 8
Message 1 of 9
pdsfishhouse
2955 Views, 8 Replies
Pedit vs Join
I am joining plines on the same layer, etc.  I was taught to use PEDIT-Join but noticed that I can do the same function with just the JOIN command.  Is there any difference?  Is one better/safer to use?
8 REPLIES 8
Message 2 of 9
Jay_B
in reply to: pdsfishhouse
Edit, I'm not finding much differences between the 2.
HTH
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 9
I concur on this assessment of the two. Although I find myself using mpedit when I have multiple lines and curves to join into a polyline.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Message 4 of 9
if you have 2 lines whereas one is the extension of the other (line1 and line2 at the same angle) you'll see a difference in the resulting vertices.
_PEDIT ==> _JOIN results in 2 polyline-segments,
_JOIN (as command) results in one new line starting at startpoint from line 1 and ending at endpoint of line 2
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 9
Neilw_05
in reply to: Alfred.NESWADBA
This is news to me. It would be useful for cleaning up line work in GIS scenarios (i.e. PLSS section lines that have multiple segments between section corners).
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 6 of 9
Neilw_05
in reply to: Neilw_05
I spoke to soon. After running a test I see the Join command does not remove the intermediate vertices if the series of lines form a shape. In other words it only works if ALL the joined lines are aligned.
WIN 10 64 PRO
Message 7 of 9
Alfred.NESWADBA
Therefor you can use command _MAPCLEAN with the options "Dissolve Pseudo Nodes" and "Simplify Objects"shown in the video, it's not exact the same as it also connects items that are not exact the same angle (depending on the value of the tolerance), but it's great for generalizing and the wish you have I think.
Run the command twice, as simplify can't work on the separeted lines/in the first pass.
- alfred -
Alfred NESWADBA
Message 8 of 9
Neilw_05
Hah, after all these years I've never been able to get MapClean to do that. I'll have to examine your workflow to see why it works for you.
WIN 10 64 PRO
Message 9 of 9
Thank you! This is very useful!
Rail Community
