Valued Contributor
KevinSpear_PE
Message 1 of 3 (375 Views)
PDF viewport layer control
375 Views, 2 Replies
03-07-2012 09:25 AM
If you have more than one PDF overlay, you might put them on separate layers.  Generally speaking in this case, the PDF extents overlap so when i plot different sheets, I would want only a single PDF to be visible.
So, my first thought was to freeze the layers of unwanted PDFs in the viewport.  Except, once i did that, nothing happened.  So, i guess i have to manually freeze the layer when plotting each sheet?  I then can't publish the layouts as the appropriate PDF's won't be visible.
Anyone have ideas?
Kevin
sboon
Message 2 of 3 (357 Views)
Re: PDF viewport layer control
03-07-2012 12:13 PM in reply to: KevinSpear_PE
Valued Contributor
KevinSpear_PE
Message 3 of 3 (353 Views)
03-07-2012 12:16 PM in reply to: sboon
If they were used all at the same scale, that would work. I have 2 at one scale and 3 at other scales.  Ironically, the 3 at the larger scale aren't a matchline scenario. But more of a turn of the head to focus on another area of the site.
Thanks for the reply! Good thought about clipping.  Had slipped my mind.
Kevin
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
