Civil 3D Forum
PDF viewport layer control
2 REPLIES 2
KevinSpear_PE
598 Views, 2 Replies
If you have more than one PDF overlay, you might put them on separate layers.  Generally speaking in this case, the PDF extents overlap so when i plot different sheets, I would want only a single PDF to be visible.
So, my first thought was to freeze the layers of unwanted PDFs in the viewport.  Except, once i did that, nothing happened.  So, i guess i have to manually freeze the layer when plotting each sheet?  I then can't publish the layouts as the appropriate PDF's won't be visible.
Anyone have ideas?
Kevin
2 REPLIES 2
sboon
in reply to: KevinSpear_PE
What about clipping the pdf's to avoid overlaps?
http://lynn.blogs.com/lynn_allens_blog/2009/03/an-autocad-2010-clip-hip-tip-for-the-weekend.html
Steve
Expert Elite Alumnus
KevinSpear_PE
in reply to: sboon
If they were used all at the same scale, that would work. I have 2 at one scale and 3 at other scales.  Ironically, the 3 at the larger scale aren't a matchline scenario. But more of a turn of the head to focus on another area of the site.
Thanks for the reply! Good thought about clipping.  Had slipped my mind.
Kevin
Rail Community
