I have two surfaces that I have successfully pasted together, and I was wondering the best way to merge the contours together at the point where the two surfaces meet. The point at which the contours meet are slightly off a har and look a little jagged. Do I manually smooth them out, or is there a command that will do this?
Likely the reason for the mismatch is due to the seam of the pasted surface not being at precisely the same elevations as the surface below it. To remedy that you will need to ensure the boundary of the paste surface is draped on the surface below. How you go about doing that depends on how your boundary was created.
This may help. As Neil said the important part is to get the smaller inner boundary to lie exactly on the larger surface.
http://www.civil4d.com/2010/04/blending-surfaces/
John Mayo
I sometimes create two boundaries for each surface which have a gap between each other (depending on the accuracy of them). For accurate or tied together surfaces I would use a small gap (0.01m) or none at all and inaccurate surfaces such as Lidar etc I use a 10-20m gap.
I then cut a hole using a hide boundary in the outer (larger) surface and paste the surfaces together to form a new composite surface.
This ends with a hole between the two surfaces but if you add the two boundary lines as breaklines and ensure that they are above the pasted surfaces in the edits it will (most times) fill in the gap for you.
In the situation of surfaces which are inaccurate the larger gap between will automatically blend between the surfaces taking out any level differences between the two, dependent on where the boundary lies. If it's over a ditch you may consider tweaking it's position so that it lies outside.
M.
I'd go with the method jfmayo posted. But to answer your question. There is a Smooth Surface command - AeccSmoothSurface.
Allen
Allen Jessup
CAD Manager - Designer
If I can add to Allen's post that smoothing can be isolated to specific areas on the surface. It does'nt have to smooth the entire surface.
John Mayo
thank you for all of your suggestions....I am going to try these and I will get back to all of you and let you know how I make out....probably sometime later today:)
