Civil 3D Forum
Pasting Surfaces
1 REPLY 1
martin888888
220 Views, 1 Reply
Pasting Surfaces
When you paste a surface into another how does it connect the surfaces?  Does it create a vertical wall where at the edge of the paste surface?  Can you tell it to grade a certain slope to the surface you are pasting into?
1 REPLY 1
Joe-Bouza
in reply to: martin888888
The pasted surface replace all the z data at the corresponding x,y. the only transition you get is to the nearset xyz. So yes you can get a near vertical face. I you are pasting A into B and wnat a controlled transition - do that before pasting. Then you are asured xyz (A) = xyz (B) and the paste is seemless.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Rail Community
