I created a new surface in Civil 3d 2011. I pasted two surfaces into this one to create one overall surface. When I did this, I turned off the surface "triangles and contours" for my other two surfaces. Now when I turn something on or off in my overall surface, the last surface I pasted into the overall also turns the same layers on and off. Why is this happening? and is there a way to fix it?
Solved by Jeff_M. Go to Solution.
Solved by TonyLeggieri3279. Go to Solution.
Any chance you have the same style applied to the overall and the last pasted surface?
UH..........yes, I have the same style for all surfaces. That was really stupid of me. I knew they were using the same style, but for some reason I was thinking I could change the look of each by doing edit styles for each individual one.
