I made 3 surfaces and pasted them together in my FG surface and all was fine. But after some time one of the surfaces goes bad and develops red strike out circle in the definition tab, and no longer displays in FG. There are no circular refs and the the host is a native. Everything seems lean and clean. Any ideas?
Joe Bouza
How are the three surfaces defined - by corridors, grading or other? If you use xml to transfer them to a new drawing and paste them together there what happens? Can you post the file?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Hi Steve
2 Feature line and 1 grading. I 'll get them up on Monday - Thanks
Joe Bouza
Did you get around this Joe? I'm having the same issue. Lean clean surfaces with common tie lines in 3 dimensions for each and every vertex but I keep getting Error peforming Edit error...
John Mayo
Joe Bouza
