Active Contributor
1 Kudo
Post 1 of 5
Pasting Corridor Surfaces
208 Views, 4 Replies
04-11-2014 01:13 PM
I can paste both a working surface and a surface from a corridor referencing the working surface to a final surface. But, when I try to paste another surface from a different corridor referencing the same working surface to the final surface, I get an error editing surface. Why can't I seem to add a second corridor surface to the final surface?
Jeff
Do either of these corridors occur in the same horizontal area? If so, you may need to create a temporary surface to paste the original ground and the first corridor.  Then adjust the second corridor to target this new surface.  Then your final surface would have the original surface, the first corridor surface and the second corridor surface.
343 Kudos
Post 2 of 5
Re: Pasting Corridor Surfaces
04-11-2014 01:27 PM in reply to: jpc5520
possibly some sort of circular reference occuring?
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Active Contributor
1 Kudo
Post 3 of 5
04-11-2014 01:37 PM in reply to: jpc5520
That's what I thought at first. But, both corridor surfaces reference the working surface. So, once I have pasted the working surface onto the final surface, when I paste the first corridor surface, it should cause a circular refference if that was the case.
Jeff
Valued Contributor
8 Kudos
Post 4 of 5
04-11-2014 02:16 PM in reply to: jpc5520
Active Contributor
1 Kudo
Post 5 of 5
04-11-2014 03:08 PM in reply to: jpc5520
That was it. Both corridors resided in the same horizontal space due to the curves. I broke up the corridors and now they work.
Jeff
