Civil 3D Forum
Pasting Corridor Surfaces
4 REPLIES 4
JeffCamarena
508 Views, 4 Replies
I can paste both a working surface and a surface from a corridor referencing the working surface to a final surface. But, when I try to paste another surface from a different corridor referencing the same working surface to the final surface, I get an error editing surface. Why can't I seem to add a second corridor surface to the final surface?
Jeff
4 REPLIES 4
neilyj666
in reply to: JeffCamarena
possibly some sort of circular reference occuring?
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
JeffCamarena
That's what I thought at first. But, both corridor surfaces reference the working surface. So, once I have pasted the working surface onto the final surface, when I paste the first corridor surface, it should cause a circular refference if that was the case.
Jeff
Do either of these corridors occur in the same horizontal area? If so, you may need to create a temporary surface to paste the original ground and the first corridor.  Then adjust the second corridor to target this new surface.  Then your final surface would have the original surface, the first corridor surface and the second corridor surface.
JeffCamarena
That was it. Both corridors resided in the same horizontal space due to the curves. I broke up the corridors and now they work.
Jeff
Rail Community
