Civil 3D Forum
Paste to Original Coordinate Issue
13 REPLIES 13
Message 1 of 14
onsionsi1
3319 Views, 13 Replies
Hello There,
I have some problem with paste to original coordinate that it appears as grey in right click as shown in attached file but it can paste from ribbon.
Any help will be appreciate.
Thank you.
Please do not forget approve as solutions and Points
to Remember Please Accept as Solution and Kudos Please
13 REPLIES 13
Message 2 of 14
neilyj666
in reply to: onsionsi1
Happens to me in both 2011 and 2012 versions - no known fix.
I put the command on a toolbar (could try quick access) then its always available
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 14
Joe-Bouza
I'm wblock, insert guy.
I think though, when I have used it,  it greyed out when I specified a base point. It worked if I only copied and pasted to original coords.
Joe Bouza
Message 4 of 14
BrianHailey
in reply to: Joe-Bouza
I just tried it both ways (copy and copy w/ basepoint) and it made no difference. I was able to paste to original coordinates in both cases so I don't think that may be the cause. I have seen this as well and whenever I see it I just use the command off the ribbon.
If I remember correctly, when I investigated this at one point, the paste to original coordinates command on the right click menu in the CUI had an extra hot key (you know, those underlined letters in a menu) and when I removed that it worked correctly. It's been a while so I may have be mistaken.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 5 of 14
onsionsi1
I figered out the solution try to select any object even autocad or civil object and right click and clipboard and then you will get paste to original cooridinate appears and you can use it.
If anyone get this solution please tell me.
Thank you.
Message 6 of 14
pjfontes
Dear Autodesk,
PLEASE FIX THIS ISSUE.
It has gone on way too long.  This is incredibly annoying!
Sincerely, CAD users everywhere. 🙂
Message 7 of 14
I have seen this issue when trying to paste into the same drawing of one with the same name, but only then.  Oddly, "paste" will work and ask you for coordinates.
Conan Witzel
Message 8 of 14
pjfontes
I'm sure many users have noticed patterns and have a few work-arounds.  It should just workSmiley Frustrated
Message 9 of 14
Jamie.Besso
My work around was to make an alias command. The command line command is PASTEORIG so just make a short one or two letter combination and it makes the task pretty quick. So now I use "Ctrl C" to copy and "PO" to paste to original coordinates.
Message 10 of 14
vlsheehan
Are you pasting from one file to another or within the same file? When I Paste to Original Coordinates within the same file it does not work. I usually copy everything using Copy with Base Point around 0,0 and use the Paste then type 0,0. I guess you could setup a button to manually Paste around 0,0.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 11 of 14
Jamie.Besso
in reply to: vlsheehan
No, our office doesn't use multiple layouts so I always copy between files. I suppose a simple lisp routine would solve that issue for you.
Jamie
Message 12 of 14
antoniovinci
What for pasting in the same file, sir?
Message 13 of 14
Jamie.Besso
in reply to: antoniovinci
I assume if you are pasting to original coordinates within the same file you are doing so between multiple layouts. Wouldn't make much sense to do this in model space....
Message 14 of 14
vlsheehan
in reply to: Jamie.Besso
Yes, we use multiple layout tabs for sheets. I will paste objects from one tab to another.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Rail Community
