Distinguished Contributor
onsionsi1
Message 1 of 14 (1,853 Views)
Paste to Original Coordinate Issue
1853 Views, 13 Replies
12-24-2011 01:32 AM
Hello There,
I have some problem with paste to original coordinate that it appears as grey in right click as shown in attached file but it can paste from ribbon.
Any help will be appreciate.
Thank you.
Please do not forget approve as solutions and Points
to Remember Please Accept as Solution and Kudos Please
neilyj
Message 2 of 14 (1,850 Views)
Re: Paste to Original Coordinate Issue
12-24-2011 02:27 AM in reply to: onsionsi1
Happens to me in both 2011 and 2012 versions - no known fix.
I put the command on a toolbar (could try quick access) then its always available
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Joe-Bouza
Message 3 of 14 (1,836 Views)
12-24-2011 07:10 AM in reply to: onsionsi1
I'm wblock, insert guy.
I think though, when I have used it,  it greyed out when I specified a base point. It worked if I only copied and pasted to original coords.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
BrianHailey
Message 4 of 14 (1,825 Views)
12-24-2011 02:28 PM in reply to: Joe-Bouza
I just tried it both ways (copy and copy w/ basepoint) and it made no difference. I was able to paste to original coordinates in both cases so I don't think that may be the cause. I have seen this as well and whenever I see it I just use the command off the ribbon.
If I remember correctly, when I investigated this at one point, the paste to original coordinates command on the right click menu in the CUI had an extra hot key (you know, those underlined letters in a menu) and when I removed that it worked correctly. It's been a while so I may have be mistaken.
Brian Hailey
CAD-1.com
My Blog
onsionsi1
Message 5 of 14 (1,815 Views)
12-24-2011 11:32 PM in reply to: onsionsi1
I figered out the solution try to select any object even autocad or civil object and right click and clipboard and then you will get paste to original cooridinate appears and you can use it.
If anyone get this solution please tell me.
Thank you.
Valued Contributor
pjfontes
Message 6 of 14 (1,333 Views)
11-08-2012 06:30 AM in reply to: onsionsi1
Dear Autodesk,
PLEASE FIX THIS ISSUE.
It has gone on way too long.  This is incredibly annoying!
Sincerely, CAD users everywhere. :smileyhappy:
Valued Contributor
witzel
Message 7 of 14 (1,309 Views)
11-08-2012 09:59 AM in reply to: onsionsi1
I have seen this issue when trying to paste into the same drawing of one with the same name, but only then.  Oddly, "paste" will work and ask you for coordinates.
Conan Witzel
Valued Contributor
pjfontes
Message 8 of 14 (1,305 Views)
11-08-2012 10:11 AM in reply to: witzel
I'm sure many users have noticed patterns and have a few work-arounds.  It should just work:smileyfrustrated:
Active Member
Jamie.Besso
Message 9 of 14 (205 Views)
07-16-2014 08:35 AM in reply to: onsionsi1
My work around was to make an alias command. The command line command is PASTEORIG so just make a short one or two letter combination and it makes the task pretty quick. So now I use "Ctrl C" to copy and "PO" to paste to original coordinates.
Valued Contributor
vsheehan
Message 10 of 14 (183 Views)
07-16-2014 12:33 PM in reply to: onsionsi1
Are you pasting from one file to another or within the same file? When I Paste to Original Coordinates within the same file it does not work. I usually copy everything using Copy with Base Point around 0,0 and use the Paste then type 0,0. I guess you could setup a button to manually Paste around 0,0.
Vincent Sheehan
http://polyin3d.blogspot.com
