I used the function paste to combine three surfaces in one. It could represent a highway. I noticed that when surfaces cross or pass close to each other some extra triangles show up trying to stitch together the surfaces. I can not find an option that can stop this, eg "not create extra triangles". Can anyone tell me why these extra triangles occur? Can you limit it?
Thank for your reply!
No, setting maximum triangle length does not help!
Program generates triangles where the distance is minimum!
Paste stitches together two surfaces in order to make a new one.
For ample working with grading if you want to show the cut portion in exiting ground, you have to make an extra surface of bottom and walls of the hole and paste it into EG. C3D then cuts off around the top of the hole and removes the "roof".
But im my case I do not want extra triangles!
Mark Green
Working on Civil 3D in Canada
