I creating a dam using 15 surfaces. I plan incorpoated the surfaces into one master surface to get the total earthfill pay quantity. When I tried to paste surface 11 with the rest I got a error window: "error performing edit". I can still edit the original surface and have been able to paste other surfaces into the master surface. Any suggestions? Thanks
PS: I am using Civil 3D 2010.
Solved by keithknifer. Go to Solution.
My guess would be-your surface 11 is a data shortcut. It needs to be promoted to the dwg to paste it.
This is not true. A surface may be posted as a datashortcut. We do this all the time. The error performing edit message is much more difficult to pin down. It seems to occur for a variety of difficult to determine reasons, including data errors, circular references, too many surfaces pasted, surface name containing spaces, and general drawing errors. It is quite vexing.
