One of my part list is behaving oddly. I recently modified only the material definition and now the pipes of that material don't draw, when creating by object. they draw if direct drawing a network. The odd part is if I go to swap parts the list is blank, then the drawing goes kablooey.
happens in any drawing.
Solved by Joe-Bouza. Go to Solution.
If it's happening in any drawing, then most likely there's a small anomoly in one of your part catalog XML files. Can you revert to an original OOTB copy of your pipe catalog and test from there? it could be so many things, so it would be difficult to troubleshoot without the files.
Joe Bouza
