I am getting the following error when trying to validate my part.
ERROR: Sample Expanded Table Row not fully expanded (calc error)
My part works fine as far as I can tell. when I change dimintions it changes to what it is supposed to. I don't know where to start to isolate what is causing this error. Any help would be appreciated.
Solved by mgsell. Go to Solution.
Hi mgsell-
Although I have not seen this exact error before, I have seen the calculation errors before. These are typically due to a Calculation value set to zero. For example:
ColumnCalc desc="Structure Height" dataType="float" unit="inch" name="SBSH" id="CCA7" visible="1" context="StructHeight" index="0">0.0000</ColumnCalc>
This needs to have a default value other than zero.
Good luck!
Thank you Seth for your reply. All my Model parameters have a value greater than 0. the error still persists. Here is my xml file.
I found it. You were right it was one of the calcs. For somereason it did not like a parameter with an underscore. Riser_Height that I had, even tho it did the calculation correctly. When I changed it to RiserH it validated fine. Thanks for your direction.
I took a look and I did not pick up on the "_". Good catch!!
Glad I was able to "nudge" you in the right direction
Same issue. I wasnt able to determine the source of the error. I also had a calculation which used an underscore. I removed the underscore and validation was successful. Kudos to you!
