Does anyone know if it's possible to use a custom properties within part builder to calculate pipe sizes?
Within part builder I have created a new parametric part under the rectangular pipe chapter.
This new parametric will represent a electrical conduit ductbank that will vary in size depending on the number of conduits in the ductbank. For example a 2 x 3 ductbank would have 2 columns and 3 rows of a 3" conduit. So the width and height of the rectangualr duct bank would be calculated this configuration. I will have up to 12 rows and coluimns in a single ductbank, so I might have a 10x10, 3x12, 12x 1, etc.
I have a custom pipes catalog and within the AeccPartParamCfg.xml I have created 2 custom propertes named ROWS & COLUMNS.
My question is can this custom property be used to calculate the the height & width on the rectangular pipe within part builder? Once I draw my pipe I would like the ability to edit ROWS & COLUMNS within the Pipes Properties to change its size. is this possible? See image below.
Hi Paul-
Judging from your screen shot, it appears that you have attempted it and it did not work. I also gave it a shot with no luck. From my perspective it does not seem like this is possible. Anyone else care to chime in with thoughts/suggestions?
check out this post by Seth Hall over at Being civil.
http://beingcivil.typepad.com/my_weblog/2010/07/assigning-optional-properties-to-a-part-size.html
and this one over at Design and motion by John Evans
Thanks.. I have read those links. I have no problem assigning custom properties. The question or problem I have is can a custom property be used to help calculate the part size?
