Civil 3D Forum
Part Building: Assigning Custom Properties
3 REPLIES 3
graf_p
452 Views, 3 Replies
Does anyone know if it's possible to use a custom properties within part builder to calculate pipe sizes?
Within part builder I have created a new parametric part under the rectangular pipe chapter.
This new parametric will represent a electrical conduit ductbank that will vary in size depending on the number of conduits in the ductbank. For example a 2 x 3 ductbank would have 2 columns and 3 rows of a 3" conduit. So the width and height of the rectangualr duct bank would be calculated this configuration. I will have up to 12 rows and coluimns in a single ductbank, so I might have a 10x10, 3x12, 12x 1, etc.
I have a custom pipes catalog and within the AeccPartParamCfg.xml I have created 2 custom propertes named ROWS & COLUMNS.
My question is can this custom property be used to calculate the the height & width on the rectangular pipe within part builder? Once I draw my pipe I would like the ability to edit ROWS & COLUMNS within the Pipes Properties to change its size. is this possible?  See image below.
3 REPLIES 3
SethHall
in reply to: graf_p
Hi Paul-
Judging from your screen shot, it appears that you have attempted it and it did not work. I also gave it a shot with no luck. From my perspective it does not seem like this is possible. Anyone else care to chime in with thoughts/suggestions?
Seth Hall
Product Owner
Model Builder
andrewpuller3811
in reply to: graf_p
check out this post by Seth Hall over at Being civil.
http://beingcivil.typepad.com/my_weblog/2010/07/assigning-optional-properties-to-a-part-size.html
and this one over at Design and motion by John Evans
http://designandmotion.net/autodesk/aec-pages/autocad-civil-3d/civil-3d-part-builder-solutions/#more...
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
graf_p
in reply to: andrewpuller3811
Thanks.. I have read those links. I have no problem assigning custom properties. The question or problem I have is can a custom property be used to help calculate the part size?
Rail Community
