I'm looking for a parking bay dynamic block that I thought was included in the OOTB Civil 3D but I can't find it - does this exist or did I imagine it??
Solved by Joe-Bouza. Go to Solution.
Solved by Jay_B. Go to Solution.
Are you referring to these included dynamic blocks?
C:\Program Files\Autodesk\AutoCAD 2015\C3D\Sample\Dynamic Blocks\
Parking Tools - Imperial.dwg
Parking Tools - Metric.dwg
There are more available under this location within these files:
C:\Program Files\Autodesk\AutoCAD 2015\Sample\en-us\Dynamic Blocks\
Civil - Imperial.dwg
Civil - Metric.dwg
Thanks for the replies - glad I hadn't imagined it...!!!
Interestingly in the UKIE version, there is a tool palette for these blocks but they are incorrectly pathed - the C3D folder is missing after AutoCAD 2015\
I just copied the Dynamic blocks folder from C3D\..... to AutoCAD 2015\... and all works now.
Tuesday, November 17, 2015
I used Google to search for AutoCAD Civil 3D 2015 dynamic blocks on the internet and
saw your question. I have been working for a landscape/civil engineering company for
just 4 months and have made some parking bays as dynamic blocks. I have designed
them so I can pick 18', 19' or 20' length spaces with the visibility parameter then I can
array the spaces however long I need them to be and I even have a sidewalk with a 6"
curb and control joints spaced at 5' center-to-center that I can stretch it to any length
that is desired and I can stretch it to any width desired also. I also have a dynamic block
that has angled parking bays with a dynamic sidewalk attached to one side. I even have
the layers and colors built into the block so individual lines can be turned off and on. If
anybody is interested in this, please feel free to reply back to this message.
AUTOCAD CIVIL 3D 2015 USER
IN WV, UNITED STATES
Try this one
it is in a container drawing either open and clipboard or explode on insert
Joe Bouza
I'd like to see your blocks if you are willing to share. I've designed some linestyles in Microstation to handle some of these layout tasks. It would be nice to have an Autocad solution as well.
Don't forget the Good 'Ol Design Center for seeing what content is included in the products. You can easily add anything you find to a tool palette.
Joe Bouza
I know where you got that. 🙂
Here's a similar one that automatically counts the stalls. 😛
Bonus ADA stalls included.
John Mayo
me too. Hey I'm having problems with them. I dont use them regularly since I do very little parking jobs, but in updating our Tps I noticed the counts are not updating. can you take a look see.
Joe Bouza
Tell them to regenerate the screen. Yours works on my end. Didn't notice it at first. Mine also required the regen to update the tag.
John Mayo
Joe Bouza
When I insert your block and double click it the attribute editor opens. When I do the same with mine the block editor opens. Do you have something else set with the atts?
John Mayo
Joe Bouza
@jmayo-EE If I start a new dwg based on acad.dwt they work fine. Something gor into my civil3d dwt file thats causing this. What could it be?
Joe Bouza
Not really sure Joe. I would start with the attribute commands and sys variables. Do you have any of these triggered in your template that are different from the acad.dwt?
John Mayo
Something goobed up in the dwt file? I restored to an earlier date and all is fine. My diary says the only change I made after the restore date was add some pipe label styles. The blocks work as expected again, but I'm perplexed as to how that could gum things up?
Joe Bouza
