Hello, I have a user that asked me a question yet I do not know Civil 3D.
Can someone help me answer this?
Thank you in advance.
"I exported parcel data from the local municiple server and inserted it into my drawing but the parcels are filled and when I click on the properties, they are map objects. Is there a way to turn them into polylines?"
Solved by jkier. Go to Solution.
Sounds like they are importing esri shape files through the Map Workspace and its appying a theme.
If they import the .shp file from the map import button in the insert ribbon and check the import polygons as closed polylines they should come in as polylines
