I am wondering if I am going about this the wrong way. I drew a polyline to create a parcel. I created the parcel. I then label the segments of this 5 segment parcel, with 4 lines and 1 curve. I label them as tags, so it starts L1, L2, L3, C1 and L.....5???? What gives? Should I label my line tags first then do the curve, or if I label the curve first will it start labeling my lines with L2???
Solved by Jeff_M. Go to Solution.
Frustrating, Thanks Jeff.
