I'm using tag labels and parcel tables to define baseline geometry for construction. My table includes the tag number, the start northing, the start easting, the bearing of the line or chord segment, the line or curve length, and the curve radius.
First, the start nothing/easting populated in my table is not the point of beginning for the selected segment. It is the end of the segment. Reversing the baseline corrected the northing/easting problem but reversed my tag numbers. I had to change the table data format to end northing and end easting to properly label the segment in the table and still maintain my tag sequence.
As far as solutions go it worked although it took considerable more time than writing that last paragraph to dance around the problem.
Now that my table displays the correct geometry, I am unable to bring the table into a viewport without other model space objects appearing as well. I need help with this issue. I've moved that stinking table across more space than the Enterprise and I'm still getting model space trash in my viewport. Any ideas?
