My students are drawing subdivision plats. In Minnesota we must have a heavy line weight for the plat boundary, a medium lineweight for block boundaries and lighter for lot lines. We cannot seem to achieve that using parcel segments, even though we're using separate layers and have all linear properties set to BYLAYER.
A give lot may have a segment that is part of the plat boundary, one or more that are block boundaries and one that is a lot boundary. Even though the 3 layers have different lineweights, all seem to plot at the widest.
Help is appreciated.
Have you looked at the parcel display hierarchy?
Tim
If you have them on the correct layers, check the "display lineweights" option. From the command line "LWDisplay"
0 is off, 1 is on.
Surveyor Lee
