Civil 3D Forum
parcel segment not labeling
2 REPLIES 2
Scott Wolfe
153 Views, 2 Replies
When I use the create parcel by layout and then use the add fixed line and and fixed curve method of creating a parcel, the segments will not label. They won't label if is tell it to automatically label or label parcel by segment or multiple sements.
The work around is to create parcel by object.
Scott Wolfe, PE
2 REPLIES 2
in reply to: Scott Wolfe
Another workaround is save the dwg (with parcels segments created by layout method) and reopen; you can label now single/multi-segment Will investigate into why it it not labeling to start with! Thanks Chakri "Scott Wolfe" wrote in message news:995652.1100726372993.JavaMail.jive@jiveforum1.autodesk.com... > When I use the create parcel by layout and then use the add fixed line and and fixed curve method of creating a parcel, the segments will not label. They won't label if is tell it to automatically label or label parcel by segment or multiple sements. > > The work around is to create parcel by object. > > Scott Wolfe, PE
Scott Wolfe
Thanks, That is a much better work around. I'll try that next time.
Scott Wolfe
Rail Community
