Civil 3D Forum
Parcel segment linetype control?
2 REPLIES 2
ctbailey
310 Views, 2 Replies
Has anyone determined a way to change only a single segment of a parcel linetype?
For example: we have a four sided parcel, and the back "line" should be drafted as a stonewall linetype.
I can set an entire parcel to be a stonewall, but I do not know how to isolate only one segment of my parcel and change that one segment.
Thanks for any ideas anyone may have.
Craig
_______
Craig T. Bailey, PE, LLS, PSM
Bailey Associates
www.bailey-associates.com
2 REPLIES 2
ctbailey
in reply to: ctbailey
I figured I should update this extremely old post.
If you design a parcel using LINE segments you can accomplish a "sideline-hide-through-a-stonewall."
Use the convert objects command, and pick your individual line & arc segments to build the parcel.  Its OK to select "delete objects"
Then select just those parcel segments that are co-incident with the stonewall linework, and set just that parcel segment to a non-plotting layer.
The parcel stays intact, and the parcel segment label still plots.
_______
Bailey Associates
tcorey
Five years later. That's dedication, my friend.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
