I figured I should update this extremely old post.
If you design a parcel using LINE segments you can accomplish a "sideline-hide-through-a-stonewall."
Use the convert objects command, and pick your individual line & arc segments to build the parcel. Its OK to select "delete objects"
Then select just those parcel segments that are co-incident with the stonewall linework, and set just that parcel segment to a non-plotting layer.
The parcel stays intact, and the parcel segment label still plots.
Five years later. That's dedication, my friend.
