Hello everyone!
I was upgraded to version 14 on Friday, and when I opened my drawing that was started in version 2011, the parcel that I created looks different, and not in a good way. My parcel boundary now appears as if it were a polyline with linetype generation is enabled, whereas in previous versions, linetype generation would reset at each vertex. How do I change the way my parcel segments display in version 14? Any advice would be greatly appreciated!
ERIK
This is a guess here, but I believe that if you create a Parcel from a Polyline of other closed object or continuos polyline then you will get linetype generation and there's nothing that can be done about it.
However if you create the same parcel with individual segements, then there will only be linetype generation for the single segment.
Rick Jackson
Survey CAD Technician VI
