From the Help Section:
"Parcels can be moved to a different site, but the original relationship to the other parcels in the original site is lost."
OK, so does that imply that those Parcels keep their original relationships in the new Site?
Dave
Dave Stoll
Las Vegas, Nevada
Solved by fcernst. Go to Solution.
No. For Parcels to have relationships, they must be in the same Site.
Fred,
So if you Move Parcels to another site, you're just transfering what, Polylines? And how about Copying Parcels into a new Site, is all lost in both Sites?
Dave
Dave Stoll
Las Vegas, Nevada
Hey Dave,
I think a quick way to demonstrate the behavior for you is to create two closed polyline objects in a test drawing that overlap each other. Then convert them to Parcels, they will probably default to your Site 1 for typical settings.
Then right-click one of them and choose Move To Site. Create a new Site called Junk.
Now right-click the parcels and move just one, then both, etc. between the two sites to see the behavior.
Thanks, Fred. Good suggestion. That should tell me what I need to know.
Dave
Dave Stoll
Las Vegas, Nevada
Right... you can Copy To Site also through the shortcut menu for your testing.
Thanks, Fred. My path to understanding is set.
Dave
Dave Stoll
Las Vegas, Nevada
THis is a very good exercise that Fred gave. Just note that if you creat the parcels on different sites your Property 1 would not be created. In this case you will have two C3D valid but overlapping parcels.
John Mayo
Dave,
After that create an Alignment through the Parcels.
Move the Alignment and Parcels, between the Sites, in different Site combinations.
Thanks, Fred. I'm on it!
Dave
Dave Stoll
Las Vegas, Nevada
