Civil 3D Forum
Parcel Relationships in a New Site
9 REPLIES 9
Message 1 of 10
Pointdump
468 Views, 9 Replies
From the Help Section:
"Parcels can be moved to a different site, but the original relationship to the other parcels in the original site is lost."
OK, so does that imply that those Parcels keep their original relationships in the new Site?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
9 REPLIES 9
Message 2 of 10
fcernst
in reply to: Pointdump
No. For Parcels to have relationships, they must be in the same Site.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 3 of 10
Pointdump
in reply to: fcernst
Fred,
So if you Move Parcels to another site, you're just transfering what, Polylines? And how about Copying Parcels into a new Site, is all lost in both Sites?
Dave
Dave Stoll
Las Vegas, Nevada
Message 4 of 10
fcernst
Hey Dave,
I think a quick way to demonstrate the behavior for you is to create two closed polyline objects in a test drawing that overlap each other. Then convert them to Parcels, they will probably default to your Site 1 for typical settings.
Then right-click one of them and choose Move To Site. Create a new Site called Junk.
Now right-click the parcels and move just one, then both, etc. between the two sites to see the behavior.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 5 of 10
Pointdump
Thanks, Fred. Good suggestion. That should tell me what I need to know.
Dave
Dave Stoll
Las Vegas, Nevada
Message 6 of 10
fcernst
Right... you can Copy To Site also through the shortcut menu for your testing.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 7 of 10
Pointdump
Thanks, Fred. My path to understanding is set.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 10
jmayo-EE
THis is a very good exercise that Fred gave. Just note that if you creat the parcels on different sites your Property 1 would not be created. In this case you will have two C3D valid but overlapping parcels.
John Mayo
Message 9 of 10
fcernst
Dave,
After that create an Alignment through the Parcels.
Move the Alignment and Parcels, between the Sites, in different Site combinations.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 10 of 10
Pointdump
Thanks, Fred. I'm on it!
Dave
Dave Stoll
Las Vegas, Nevada
Rail Community
