Civil 3D Forum
Parcel numbering control
6 REPLIES 6
255 Views, 6 Replies
Hey All;
The question came up on the Land side
whether C3D allows more flexibility for control (read change) of Parcel
Numbers/Names. If you were to go through with numbering all the lots in a
subdivision, and then were requested to re-number them based on their Block
status, would this be a tedious task, or simple?
Block 1, Lot 1
Block 2, Lot 1
etc.
TIA
face="Bookman Old Style">
Don Reichle
"King Of Work-Arounds"
"Progress!? We'll have
none of that around here!" 🙂
LDT3/CD3
IntelP4-2.4
1GB RAM
Intel
64MB
6 REPLIES 6
AFAIK tedious... though I would be interested in the non-tedious method...
The easiest way I have found is don't even try to number
them correct from the start.  It won't let you (my opinion, of
course).  However, it is really simple to just renumber after completion by
just using your mouse pick button.  I might also add that it appears even
easier if you start with a large number, then when you re-number you won't have
any conflicts.  I'll stand back if someone wants to start throwing things
at me.  <G>
Bill
"Don Reichle" <SPAMLESS-reichle4AThotmailDOTcom> wrote in message
href="news:4826163@discussion.autodesk.com">news:4826163@discussion.autodesk.com
Hey All;
Block 1, Lot 1
Block 2, Lot 1
etc.
TIA
Don Reichle
"Progress!? We'll
have none of that around here!" 🙂
LDT3/CD3
IntelP4-2.4
1GB
RAM
Intel 64MB
Oberer
"However, it is really simple to just renumber after completion by just using your mouse pick button"
While that sounds simple, what if you have hundreds of lots? Do you really want to spend the time editing each one? What if you make a mistake?
WHAT if the parcels were contained in a (oohhhs & ahhhs) database? Gee, then we'd have access to all kinds of parcel info that we could actually link to other databases.
Your original statement makes this all too clear 🙂
"The easiest way I have found is don't even try to number them correct from the start. It won't let you (my opinion, of course). "
The same goes for alignments. We, as users, simply shouldn't have access to the 'key' they choose to use. We deserve some simple functionaility like being able to rename an alignment or rename/renumber parcels - EASILY (please spare me the whole import / export shabang 🙂
Hey Oberer;
Thanks for following me over here for this topic. This is where the Deskers
actually listen to you. Sometimes they will implement the things we talk
about here, but maybe not in the exact form we mention, but most times
awfully close. I think they really appreciate acquiring different Real World
examples to consider.
Buckle up and hang on, the ride gets exciting from here on. 🙂
Don Reichle
"Progress!? We'll have none of that around here!" 🙂
LDT3/CD3
IntelP4-2.4
1GB RAM
Intel 64MB
wrote in message news:4826411@discussion.autodesk.com...
Don,
The latest release included improvements
to parcel renumbering and renaming. This is the command that allows
you to draw a fence through a series of parcels.
For renumbering, the duplicate number issue was
eliminated so you don't have to first renumber them to a high value. If you've
created a bunch of parcels and the numbers are all jumbled you can pick a
starting point for parcel 1 and a path through the parcels, and it will renumber
them sequentially as you would expect.
For renaming, you can set it to use a name
template, or you can override it. The numbers in the name can come from the
actual parcel number and/or using a counter (from a specified starting number)
so I think that you should be able to accomplish this.
The properties of a parcel has also been improved.
You can set it to use a the name template, or you can override it with a
manually entered string.
Glen
Hey All;
Block 1, Lot 1
Block 2, Lot 1
etc.
TIA
Don Reichle
"Progress!? We'll
LDT3/CD3
IntelP4-2.4
1GB
RAM
Intel 64MB
Thanks for the update, Glen. That info will
come in handy when I get my grubby little hands on C3D once more.
This time I think I'll hang on for dear
life.
Don Reichle
"The only thing
worse
than training your staff,
and having them leave is -
not training
your staff,
and having them stay."
Courtesy Graphics Solution
Providers
LDT3/CD3
IntelP4-2.4
1GB
RAM
Intel 64MB
Don,
renumber them sequentially as you would expect.
the actual parcel number and/or using a counter (from a specified starting
number) so I think that you should be able to accomplish this.
improved. You can set it to use a the name template, or you can override it
with a manually entered string.
Glen
Hey All;
Block 1, Lot 1
Block 2, Lot 1
etc.
TIA
Don Reichle
"Progress!? We'll
LDT3/CD3
IntelP4-2.4
1GB
RAM
Intel 64MB
Rail Community
