Civil 3D Forum
Parcel Map Inverse Not Rounding Bearings
4 REPLIES 4
TonyLeggieri3279
558 Views, 4 Replies
I have a problem where the Inverse Report is returning values of "N 89-59-60 E" instead of "N 90-0-0 E".
Any ideas how to fix this?  I have attached a screenshot.  A simple rectangular parcel rotated 1 degree.
The head of our survey department is going nuts trying to check things.
Thanks.
Tony
Civil 3D 2011 (SP1)
Windows 7 (32 bit)
Tony Leggieri
Gutschick, Little & Weber, P.A. (GLW)
CADD Manager
Civil 3D 2023.2.1
Windows 10
4 REPLIES 4
anyone?
Tony Leggieri
CADD Manager
Civil 3D 2023.2.1
Windows 10
Jeff_M
in reply to: TonyLeggieri3279
Can you use the Map Check report instead of the Inverse? It is a .NET report and does not suffer the same shortcoming.
rkmcswain
in reply to: Jeff_M
A Map Check is not the same as an Inverse.
R.K. McSwain     | CADpanacea | on twitter
I found it, the function formatAngleToDMS in the file "C:\ProgramData\Autodesk\C3D 2011\enu\Data\Reports\xsl\General_Formating_JScript.xsl" is simply not accounting for the possibility of "60" minutes or "60" seconds.
I rewrote this function and all is well.
Rail Community
