Solved by Jeff_M. Go to Solution.
Jeff,
Did you post your modified source code to this site or the swamp? I searched but was unable to find it.
thank you,
Stacy
I thought I had posted it the customization forum, @stacy.dunn, but I didn't find it, either. So I just added it to an old post where I had originally posted the source code for C3D 2009/10.
Okay, I'm starting to feel very foolish as I am sure I am just missing a step to get this to work. I have unlocked the zip file, I have extracted the files and I am not seeing any .dll files, and neither is windows/cad. Here is a screen shot of what I get after I extract the files. Also if I locate the files in question, where exactly do I place them?
Any help would be great, Thanks in advance.
@Anonymous, it looks like you grabbed to Source files zip. This includes only the source code which is used to create the dll's . If you want the prebuilt dll's and NOT the source code, I posted these in a zip file in post # 82 of this thread.
Oh, and welcome to the forums!
Hi Jeff, were still using C3D 2010, i have been looking at the parcel report is there a way to add acre display for 2010. It looks like that option was added for 2012-2016.
Thank You
Ruslan,
@Anonymous, Welcome to the forums! I had to resurrect an old laptop that still has 2010 installed in order to build a new dll, but managed to do that this morning. I was unable to test it, however, it should work just fine. Note that this version must have the 2 included files placed in the reports folder...see the older instructions in this thread.
Hi Jeff,
I just received a mark up from one of our local municipalities asking that the segments in the lot closure not be split into 2 length due to neighboring parcel lines.
I found this thread and downloaded the .ZIP file of the .dll you created. It has versions for C3D 2012 through 2016. I was wondering if the 2016 would work with C3D 2017, or should I wait for an update?
Thank you.
Marty.
Hi Jeff,
The reporting tool works. Thanks.
I have included a snip of the .txt output for reference. The output includes a lot of quote marks. These are easily dealt with by search & replace. But I thought you might want to be aware.
I can not check any version other than the 2017, as that is all I have access to.
Thanks again for your help. It is going to save me a lot of time.
Marty.
Jeff,
I came across a weird case where the merge segments option merges two lines that it shouldn't; see attached custom report, stock report and drawing. There is and angle break of 08".
