I understand what you are explaining....I can not get it to use different
labels on the same segment. From left to right, lot 1 on top, and lots 1
and 2 on the bottom, rear segmants.....label lot 1 bottom, no span...then
label lot 2 bottom, span, both ok......then go to label lot 1 top,
span....where do I pick the segment to make it label the correct dimension?
wrote in message news:5563075@discussion.autodesk.com...
Whoops, sorry, my fault. The lower lots, going from left to right, the
rear of lots 2, 5, 8 and the last lot, need spanned labels.
